blown fuse?
  • 4
09civic
so about 2 weeks ago, i was making my connections to the back of the headunit better. i never cut any wire. i just re-tied my door speaker wires. so the following night, i notice that my interior lights aren't working. i thought it was no big deal since it was just the interior lighting. so tonight, i notice that my tail lights aren't working either. my brake lights work but the constant dim that they give when driving at night do no work. could this be a fuse that is blown?
Check your fuse box for anything that is blown and also make sure that your new connections aren't shorting out anything. I had a similar problem but I don't remember what I did to fix it..it was a simple fix though
well some cars it sends a ground through that wire when the headlights are switched on. Some cars it shoots a 12v+ signal through that wire , some cars its shoots a variable + through the wire depending on where the dimmer switch is turned to. I fried a stereo one time trying to connect it in a '93 cavilier and since then i have learned to just never use it.
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
989
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
5K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
09civic
09civic
Melbourne, FL
09civic
