Blown sub?
Digital Designs
Aclministrator
2,459
Limestone NY
Well this morning I was bumping like usual, and all was fine, but then the bass just cut out. No sound or anything. I get home, pop the trunk and the amp is in protect. I was having ground problems before, so I figured that was probably the case. I redid the ground to 3 different spots, and the amp would only stay out of protect and the sub would play until 15 volume(normally around 45 when bumping.) I thought shiit my amp might be toast, but then I thought maybe its the sub. The speaker wires were really hot(hotter than what I would think they would get) I didnt bother taking the sub out of the box, but I put my DMM on the terminal on the box, and it read 0.8 ohms. My sub is a dual 4 ohm >.
that audiopipe amp is way way to much power for the type r daily...
Sub is D4 and the AP is rated at 950@2ohm. I set it with a DMM to like 46.5 volts which is like 700 watts or something. I dont remember the exact settings I put it to. But a few days ago I turned up the low frequency on the EQ a tad, and I think that is what did it.
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif en......it could be.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
993
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
5K
Digital Designs
Aclministrator
Digital Designs
Limestone NY
microhaxo
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
