Blown Subwoofer
  • 3
predxen
I just picked up a pair of MTX Thunder 8000's wired them up, and listened to them. They appeared to not be getting enough power from my ATX 1600.2 amp. So i though i would bridge one. Me being new to car audio did not know how to bridge an amp. i have since then learned my mistake. when i wired the sub the first time i took 2 speaker wires and hooked them both up to the amp, Then i twisted the positive ends of the two wires together and the negative ones together and put them in the sub. when i turned it on the amp went into protection mode. i knew i had messed up and went inside to look online only to see that i wired them wrong. i hooked up the other sub in the correct way in a bridge and it worked wonderfully. Then i tried the other sub and the amp went into protection mode. So i think i may have blown one of my MTX's, but i am not sure. if i did i was wondering where i could pick up a re-cone kit.
bridging an amp means to use one terminal from each side, one+ one- and you will have the same left over. As for the sub I don't know what you did?
You are going into protect because even though there there are 2 + and 2 -, you are only using 1 + and 1 - on the amp. There should be a line saying bridged and pointing to only one set of terminals. You bridge the speaker and then take the 2 sets of wires and put their to one channel on the amp
You are going into protect because even though there there are 2 + and 2 -, you are only using 1 + and 1 - on the amp. There should be a line saying bridged and pointing to only one set of terminals. You bridge the speaker and then take the 2 sets of wires and put their to one channel on the amp[/quote
he said it doesn't work when hooked up correctly.
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
934
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
predxen
predxen
Waterford, MI
predxen
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
