boots on stock internals
All depends on the engine. With the associated fuel upgrades, etc. I would think 12 psi is the max you could go on the LS engine. But, at the same time, if you don't tune a turbocharged engine correctly, it may blow up with ony 5 psi.
Best to browse around somewhere like http://www.honda-tech.com, etc. They might know a little more than a car audio forum //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
All I know is the stock Neon internals can handle 12 psi max (with the correct upgrades/tuning). //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
With differant fuel injectors my '94 Volvo 940 can handle upwards of 20 psi, with stock fuel injection it tops out around 14 I believe. Also depends on whether you stay with the stock turbo or not.
One important thing to remember is that 5 psi on a high compression engine is MUCH more than 5 psi on a low compression engine.
how much boost can your stock internals handle, mine can take up to 12psi on stock internals
bout 20-21 daily.
anywhere from 25-30 psi at the track. pending on tune.
I was running 22psi when I blew my trans. Pulled like a bat outta hell.
Friend just ran 23psi and a 12.12 @113.
Depends on the turbo, the cooling, fuel, and timing.
theres so much more than what the stock internals can handle, thats too generic.
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
700
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
874
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
569
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
671
the_flatlander
the_flatlander
Wisconsin
ighettoboyi
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
