Box Build for: bsean63
psych0ticnemes1
Psych0tic Customs
6,004
Behind You
This is what have I have completed so far. The box is 3 cubic feet net tuned to 35 hertz. The port is 3" wide yielding 43.5 square inches of port which isn't a ton but should be enough to get some air flowing. He wants the sub mounted on the front so instead of having the front piece mounting between the top and bottom piece, I have decided to make it the entire height of the box so that the baffle isn't too skinny at the top and bottom.
Here are some pictures of my progress:
yes, but i still dont see the advantage of building the box that way
If I made the front piece normally, the top and bottom of the front piece would only be around a 1/4 of an inch thick. By doing it this way, I have an extra .75" on both the top and bottom of the baffle.
Ex: See SPY's last thread for Slammed where he didn't account for this.
Another thing is, when the front panel sits between the top and bottom, the screws can protrude into the cutout. A problem with that is... if you dont cut your hole until after you assemble it, you have to cut through the screws with your router. I see exactly what he is doing, and there is nothing wrong with doing it that way.
that makes no sense, but if it works for you it dosent matter //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Thanks. //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
It makes perfect sense. Instead of having only 1/4" of material left between the edge of the cutout and the edge of the panel, he now has 1" because he has increased the width of the panel 1.5"
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
6
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
7
Love this sub, hate AB's site, short on info for sure. American Bass XR-10D2 box recomend: If you want to tune a 2.75 Cu Ft box (for two of these...
11
3K
psych0ticnemes1
Psych0tic Customs
psych0ticnemes1
Behind You
psych0ticnemes1
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
