Box build for Slammed
I'm sure it was a little simple mistake. he seems like a very particular guy and very easy to work with. I'm trusting him to build my box. good guy none the less
I don't know him personally, however, I do recall space being a major issue when I designing this enclosure for slammed. That .2^3 throws things off kilter enough to change the characteristics of how the sub will sound. My main concern is with the strength of the front panel. When the sub is finally mounted in place. 1/4" of play between the cutout and the end of the board isn't very much at all. And again, I am very surprised that it didn't break on him when moving it around. That definitely wouldn't fly in any kind of SPL enclosure //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I have seen some of Fishers work around here and have to say that it is pretty amazing on what some people can do with simple hand tools. As far as SPY's work goes, it looks to be decent. Better than some I have seen around here. Which is probably why he is able to build enclosures for members around here. I am by no means trying to take any sales away from him or ruin his reputation in these parts of the woods. I am simply trying to point out that he did make a mistake that has compromised the strength and overall sound of this particular enclosure.
The box was built to specs and should be the correct vol and tuning.
15.5"d x 36"w x 16"h
That being said, you are right, I did make a mistake by putting the front inside the box. This is why I prefer to design the boxes I build myself.
I will stand behind my work and if it breaks I will replace it.
Slammed please confirm that the box does have the right external dimensions and therefore is the correct vol and tuning.
Im curious if .75" was added to the depth to compromise for the internal air space due to how the front was placed.
If not, there is a significant loss in space (0.2 cu ft) and the tuning will be a bit higher as well
someone please correct me if Im wrong
also, the .25" mounting clearance for the sub makes the area pretty weak //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
SPY did a great job with my first enclosure. I was very happy with it.
People just make mistakes sometimes.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
This is what I was given for plans
And this is how I built the box
So everything about the box is the same as the plans i was given except the front baffle was placed between the top and bottom instead of over them.
The overall dimensions are the same and therefore the vol and tuning should be correct. Any clearance issures are the fault of the designer.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
6
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
7
Love this sub, hate AB's site, short on info for sure. American Bass XR-10D2 box recomend: If you want to tune a 2.75 Cu Ft box (for two of these...
11
3K
SPY
SPY
NY
Fusion_FREAK
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
