Box too small. Turn sub around for more space?
  • 6
95lincdog
Bought a dc audio m3 8". Box too small, I think if I put sub firing into box would make more volume cuz magnet is huge. But, the amount of flex is rediculous on this sub and the thickness of the box is 1". Will it rub and hurt the speaker? Or is it ok?
Yes its fine and u will gain a small amount of airspace ...make sure u turn the phase on the amp since u are running inverted
What size is the box?Ported or sealed?
You aren't going to gain much airspace just by mounting the sub inverted.
It's 17.75 x 11.75 x 11.5, the wood is 1 thick. 2 very small triangle ports on the front, but on the inside of the box, there's more wood so the air comes from the back of the enclosure. The sub displacement is .1ft^3
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
687
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
729
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
95lincdog
95lincdog
portland, OR
95lincdog
