box volume as it realted to amoutn of air being moved
  • 2
grandam888
right now my box is 7.66 cubic ft, and is tuned to 37 hz.
my goal is 33 hz, but in order to keep same box and just make port longer, i will be losing 1.66 cubes of box volume, putting me @ 6 cubes even @ 33hz and i will be adding 19.25" to the port length.
question is, what will the difference in sound ad air movement from the loss in volume.
will it move more or less air? will it sound better or worse in term of quality and spl?
P>S> sorry for the crappy typos in the title, to late to change it.
First off, 8 cubes seems huge for such a strong sub. 6 cubes may even be overkill in terms of flat response.
Youll be fine adding the port. For moving you, you really should be concerned about displacement. The BTL may not be the sub you want if thats really your end goal.
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
My subs unload at full tilt @ 28 hz, They are in 3.69 cubes net tuned to 34 hz. 4 - 8's. Big box and big power.
7
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
683
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
728
grandam888
grandam888
houston, tx
surreal
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
