Box Volume: How is the sound affected by it?
  • 3
SpeeDFX
I'm gonna build a box for my 2 shivas...
As the amount of volume goes up, does the sound get less boomy and tighter, or vice versa?
What are the advantages and disadvantages of a bigger or smaller box volume?
Should the box be built with a partition so that each sub has its own area,or combine the volumes and have 1 big space of air that the subs share.
By making the box larger, the air spring limits cone motion less and allows the system to play lower and with flatter overall response (lower Qtc) at the expense of power handling. If you go too large, however, you begin to lose efficiency in order to gain the additional low frequency extension. By making the box smaller, the air spring exerts more control and limits cone motion at low frequencies which increases power handling but does not let the system play as low and produces a more peaked response (higher Qtc.)
As far as seperate chambers. If you don't, you run the risk of blowing both subs if one goes. The divider also acts as a pretty good brace considering it's in the middle of te enclosure //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
How about the tightness of play? I'm trying to decide to go with 1.3 cf (after displacement) or around 1.5 (after displacement) in each enclosure for both my shivas. I'm looking for high sound quality...
I agree with goddyd4me. I don't believe you will really be able to tell the difference. I would go with the larger box. As Shiva's tend to like the larger enclsoures . //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
My subs unload at full tilt @ 28 hz, They are in 3.69 cubes net tuned to 34 hz. 4 - 8's. Big box and big power.
7
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
172
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
473
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
430
SpeeDFX
SpeeDFX
Altadena, CA
ramos
Latest topics
