Bracing questions
  • 2
4BangerStanger
CarAudio.com Regular
117
5
DFW
Planning a new enclosure build and could use a little insight. The box will be roughly 25w x 15h x 12d.  Based on my calculations, I have roughly .21 cubic feet to play with.  I was planning a couple window pane braces since the front will be 25" long. Should I also add some braces in the corners?  If so, what would be sufficient?  Would 3/4 x 3/4 mitered at 45 be enough?
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
For around 1k rms I’ll double up 1/2” for a 1” thickness all around. If doing a flush sub look I’ll add another .75” baffle depending on how tall...
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
393
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
4BangerStanger
4BangerStanger
DFW
THATpurpleKUSH
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
