Brand new system installed...crackle & pop = speakers dead. Now what?
  • 3
MDew1
14
WA
I just paid over $700 to have a deck, amp, front & rear speakers & powered sub installed in my 2003 Toyota Highlander in a local audio shop. It was a lightly-used deck & amp I bought elsewhere (they looked new) and brand-new speakers from Amazon. Shortly afterwards, I noticed odd crackling noises and the occasional loud pop when listening to music at relatively low volumes (from the speakers, not the sub). Then, when turning the key in my car's ignition the deck powered up, I heard a scratchy noise & pop (similar to a record needle fumbling around on a record) and all the sound went out at once. All that remained was very faint sound from the tweeters and the rumbling of the sub.
I took it back into the shop (this was 3 days after the installation) and they took it apart & verified that all of the brand-new midrange speakers were blown. The sub is still functioning fine since it was not wired to the amp. They attributed it to a sudden surge of power from the amp, and that basically it must be faulty and delivering "dirty" power. They disconnected one speaker and hooked up a test speaker and verified it was working again now...but essentially left me high & dry as to where to go next. How do I verify that it was indeed the amp that was at fault? And IF it was what recourse do I have (since returning the amp is not an option)?
Deck: Sony XAV-W650BT
Amp: Rockville RXA-F2 2400W Peak/1200W RMS 4-Channel
Front Speakers: Polk Audio DB6501 6.5" 2-Way Component System w/ speakers, tweeters, crossovers (300W Peak/100W RMS)
Rear Speakers: Polk DB652 6.5" UltraMarine Dynamic Balance Coaxial Speakers (300W Peak/100W RMS)
Sub: Rockville RW8CA 8" w/ wiring kit
I don't know what you can do about it now but that sounds fishy to me almost like they didn't have the gain set properly and the amp was clipping and that killed your speakers but I am no expert I'm sure others will chime in
Yeah that's what I'm worried about. Considering taking it into another shop for a 2nd opinion just to double-check their work since I don't really know what to look for.
amp coulda been bad or they coulda done crappy job with ground or had wires touching idk of a way to find out other than to try a new amp, see if it has noises (make sure amp ground is good 1st, no paint under it)
Diagnosis from the 2nd audio shop confirmed that the amp was fine, the problem was either due to faulty wiring or faulty speakers. I tore the speakers out in order to return them to Amazon so we'll see what happens. Judging by the reviews, it seems others have had problems with those same models.
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
  • Locked
I have a few of these head units. Brand new, unopened and ready to ship out. $925 PayPal. Shipping included to conus.
Update: The burning smell is slowly going away at middle volumes. To the point where it only comes on at middle volumes. I adjusted the sub master...
17
4K
I've got three years on my 320a iraggi. I haven't used any other brands so i can't say how it compares to others. Customer service was great...
6
If only there was a napa website with prices on it... or are you needing someone to show you how to subtract 40% from the list price?
8
MDew1
MDew1
WA
MDew1
