Bridge Stereo Signal at Speaker Level
  • 3
JexVaria
Well, hello to all firstly,
Backstory :
I noticed there was a speaker grille in the top center part of my car's dash (2005 Volvo S80), but couldn't hear any sound from it. Figured it might of been from the wires I left after installing my new HU. (Volvo has a lot non-essential wires for there factory HU) So I popped the grille to look and see the color of the wires running to it but to my surprise there was not actually a speaker in there. After rigging it some and cutting plastic I was able to get a Kenwood 6" speaker in there.
Now the problem I ran into was how to get a mono signal from stereo signal at speaker wire level (Essentially making a false center channel). Found a nifty little chart for a method just called bridge stereo.
Source : How To - Car Stereo - How To Install A Center Channel
I haven't connected it like this yet, but I'm assuming it works. BUT what I really want to know is how does this work. Looking at the diagram I can just see the signals bouncing at each other and being extremely distorted or just not working cause you have two leads running into each other. Anyone have the knowledge to explain?
That diagram appears to be for an amp that can be run in "tri mode". I would not recommend trying to make your factory sound system do that and if you don't have 5 channel processing (and music/movies recorded in 5 channel) adding a center channel is generally a bad idea.
3 ohms speakers are generally what some manufacturers do with factory systems, and wire the components in series. If your amp can do 2 ohm and 4...
5
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
The question is confusing. Connect the 4" to the radio and use the rear amp channels for the sub. If the sub is DVC you can also use it in stereo...
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
206
JexVaria
JexVaria
Knoxville, TN
hispls
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
