Bridge the amp?
  • 3
3 ohms speakers are generally what some manufacturers do with factory systems, and wire the components in series. If your amp can do 2 ohm and 4...
5
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
The question is confusing. Connect the 4" to the radio and use the rear amp channels for the sub. If the sub is DVC you can also use it in stereo...
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
Erock77
Erock77
Lancaster, PA
Incrimin18s
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
