Bridging an amp
  • 4
d_lemon0829
4
Wv
I've got 2 speakers I want to run a bridged signal to. Can i just run the + of channel 1 and - of channel 2 to one speaker and vice versa to the other, or do I have to use the + of channel 3 and - of channel 4 to the second?
Thanks, D-roy
i dont think so.
you will fry that amp.
keep 1 speaker per channel. make sure is 2ohms or up per speaker.
and just so you know, that amps is junk. is going to fry anyway.
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
981
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
131
6
364
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
666
d_lemon0829
d_lemon0829
Wv
n2audio
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
