Bridging your sub to amp?
  • 2
s5pitfire
Ello?
188
Sacto, CA
I decided to put this in general for the quickest responses...
I have a kicker amp and it's 2 channel. There is L + and L - and R+ and R -
Right now my sub is in both R's, but to bridge it do I go L+ and R- or the other way??? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif :crazy:
thanks
You are losing your stereo signal so it doesn't matter which way you go. Both should work. A lot of times on the amp it will tell you specifically like use R+ and L- or something. Look around on the bottom and in the manual.
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
984
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
204
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
542
s5pitfire
Ello?
s5pitfire
Sacto, CA
Do_
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
