bridging
  • Thread starter <Ryan V.>
  • Start date
  • Replies 4
  • Views 2K
  • 2
<Ryan V.>
Guest
right now i have a lightning strike s2.200 hooked up and i recently got a rockford punch 160. Would it be hard or stupid to bridge the two and run my highs with the lightning?
ryan v- what are the strike 200 hook up to
(componets,6x9,etc
also what do you want to run on the punch 160
componets,6x9,or subs
hopefully I understand your question. If you run an amp on the mids and highs run it in stereo, not bridged (mono) or you will lose right and left sound. If you did run 2 amps (exactly the same recommended) on the mids and highs bridged, run your right side rca to the right side speaker amp and the left side rca to the left side spkr amp
Originally posted by billetz23:ryan v- what are the strike 200 hook up to
(componets,6x9,etc
I have it hooked up to two MTX 4000
ryan v-so you have 2 mtx 4000 hookup to
your strike 200 and you want to bridge it
is your 4000 4ohm,or 8ohm if there 8ohm sub
then just wire them plus to plus and minus to minus then wire them to you bridge strike 200
but if there 4ohm subs. then you can do to things
#1 wire the two 4ohm subs in series
call the two subs sub#1 and sub#2 take the minus
from sub#1 and wire it to the plus of sub#2
then take the plus from sub#1 and the minus from
sub#2 and wire them to your bridge strike 200
the same would go if you were to use the punch
360 for the 4000 #2 use the punch 360 or the
strike 200 in stereo for you mids and highs.
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
984
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
Guest
billetz23
