Build me a system!!
  • 6
Lowflyin
Sit on my face, B*tch
1,149
FU JOSE, PA
I have 1000 to spend for a system.(wires, box, sub, amp, front)
I was originally thinking either a HDC318 or a custom 18 from SPLAUDIO on a Ap30001d or ap18001d.
I want an 18 for sure though because I'm building this for a daily ground pounder, doesn't need to meter well and i will prolly tune it around 28-32 hz.
All of this is going in an extended cab s10/sonoma. Any reccomendations?
sounds like u have a good plan for that amount of money. you have power wire? extra battery? have you dont the big 3?
i would do sub foward and port to the side al below the window line. have RAM_Designs hook you up with a design, very nice guy
No power wire, if I go with the 1800 amp it only accepts 4 guage so that would be a lot cheaper plus the cost of the amp is 100 less than the 30001d. If I go with the 30001d I will need 1/0 which is a lot more than 4 guage so I'm not sure where to go from there. Would it be worth getting the 3000 or will the 1800 be plenty? I pretty much just want something that sounds decent, gets louder than my 2 cvr 15s i had, and demos well.
optima red top under the hood and going to do the big 3 in 1/0.
With 1800 watts, will a H/o alt be necessary, what alternator comes stock in a s10/sonoma 4.3 v6?
and rams designs are only a buck arent they? if so i will do that for sure
EDIT:
No blow through and I am pretty set on a single sub set up, pretty set on an 18 also...
EDIT: X2
Was also thinking of going 4th order with an 18, not sure if ill have the space though....
no, bucks designs are only a buck, lol... but he does good work. so does ram, and pro rabbit.
as far as the amp, it really depends on the sub you choose, and so does the wiring
$279 for the 18HDC318 Copper Coil Subwoofer
amp $429
AQ2200D Amplifier
then 200 bucks for a solid extra battery (i have some //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif )
that leaves about 100 for materials for the box
Ya but what about wiress.... The 200$ I save by getting an AP will pay for them unfortunately.. I do want an aq2200 though.
I figure i will run it like that with an AP and then when i get enough ill buy the AQ and sell the AP..
what year s10,i also have a s10 mines the loudest street truck [no wall or cut thru] with 2 batts i can tell you almost any thing about s 10s.also i may have an alt for you
I would get a new 18 but not a new amp, the prices are crazy. Either get a used AQ or get an AP, you will save quite a bit
i wouldnt get new anything because of prices but some ppl are differant, i offered up new because some of the newbies are scared of used but to each is own lol. OP you can get a AP 3000.1 for 300 on ebay. do that rather than the 1800. with the big 3 and a redtop, u can buy a nice sprinter batttery off me and it will set you on power for sure! PM me if ya want any help or ideas on the build
Alternatively you can get 2 AP1500's for like $270 which is cheaper than the AP3k and gives you some more wiring options too
i agree with you .i'd get a used aq over a new ap anyday.just a way better amp in my opinion
I thought this also until someone brought up distro block, rcas and all that and I figure after that the ap3k is cheaper...
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
For sub, I recommend going true infinite baffle. You get to keep just about all of your trunk space AND sound great doing it (if you do it right.)...
7
https://www.youtube.com/@therealmatty_s/videos
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
5
Lowflyin
Lowflyin
FU JOSE, PA
Lowflyin
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
