Buzzing in speakers at high volume
vinsewah
I have a pair of Alpine Type R's in the back for rear fill and I've discovered whenever I play music at high volumes I get weird buzzing sounds. At low volumes the buzzing stops (or maybe they're too faint to be heard). So are my speakers jacked? I just got them less than a month ago...
Are the speakers in the rear deck? And, do you have a sub in the trunk? If so, the speakers are probably getting the tar beat out of them while they are being used as a passive radiators..
Edit: you bumped your own thread in a hour and a half??? Learn some patience, boy...
Ok, last ditch effort; I assume the radio high outputs do work but are capped off at the moment. Try using a passive LOC, it will be cheaper than...
37
4K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
4
Your math isn't so good. I made a mistake I'm sorry. I'm striving to be perfect like you.
5
vinsewah
vinsewah
San Jose,CA
ebrunn
