Buzzing noise ? (little noise during music).
  • 3
I am running these speakers Uranium GZUC 650SQ on a 2 channel amp.
The drivers side speakers make a buzzing noise when music isn't on and when music is on they only play about 15-20% the volume as the passenger side speakers (the passenger side speakers sound amazing, no issues).
What should I look for as potential issues ?
Loose or bad wire to the driver side speakers. Poor connection to/from the crossover. Loose RCAs (check them at the amp and HU) or bad RCAs.
This. Swap left and right RCAs at the amp and see if the trouble goes to the passenger side. If it stays at the driver's side, then it's something after where you swapped RCAs, like speaker leads, amp itself or speaker itself.
CHAD
CHAD
I swapped RCA"s and that was the issue (the drivers side sounds great and the passenger side won't play).
While I wait to get the new RCA"S in there, should I unplug the defective RCA ? (will it prevent potential damage to my speakers ?).
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
4
Ok, last ditch effort; I assume the radio high outputs do work but are capped off at the moment. Try using a passive LOC, it will be cheaper than...
37
4K
Your math isn't so good. I made a mistake I'm sorry. I'm striving to be perfect like you.
5
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
mastershake575
mastershake575
Dallas
seedlings
