Buzzing noise!!!!!
  • 2
jlanebpc
Ok I have a diamond audio 600.4 running 2 cadence 4x6 and 2 cadence 6.5 and a power acoustik 1500w pushing 2 ipipe 12's I upgraded power wire from 4g to 0g and put my amps under my seat, I havnt hooked up my sins yet because on my diamond audio a static noise is present weather the volume is up or down, I've tried running my power and ground trough a different spot RCA cables to, the noise is even present when the RCA cables are unpluged, help please lol
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
4
Ok, last ditch effort; I assume the radio high outputs do work but are capped off at the moment. Try using a passive LOC, it will be cheaper than...
37
4K
Your math isn't so good. I made a mistake I'm sorry. I'm striving to be perfect like you.
5
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
jlanebpc
jlanebpc
Shreveport, LA
Dj-torn
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
