C-pilllar wall in the Jeep
I had an amp break from vibration so I have finally re-mounted the amps off of the back of the box. At some point I'll buy a spool of red #4 power wire and tuck/hide all the wiring and I will also figure out a way to cover the batteries. Oh and while re-mounting the amps I took the batteries in to be tested and got them all warrantied. A pretty good come-up and now brand new batteries all around.
looks good man, first time i've actually seen your install //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
12
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
917
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
9
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
hispls
hispls
Central Maine
CRXBMPN
Decebal
    Jun 10, 2024
