C2 Audio Amp Prototypes
Final Numbers from Testing our Recon 1.4 Mono Amp:
Recon 1.4
MAP Pricing $399
12.0 Volt Rating:
12.0 Volt RMS power @ 1 ohm mono 1412 watts x 1CH
12.0 Volt RMS power @ 2 ohm mono 939 watts x 1CH
12.0 Volt RMS power @ 4 ohm mono 497 watts x 1CH
Efficiency 4 ohm @ 12 Volts 86%
12.0 Volts 2 Amps strapped @ 2 Ohm Mono 3120 Watts
13.8 Volt Rating:
13.8 Volt RMS power @ 1 ohm mono 1892 watts x 1CH
13.8 Volt RMS power @ 2 ohm mono 1279 watts x 1CH
13.8 Volt RMS power @ 4 ohm mono 696 watts x 1CH
Efficiency 4 ohm @ 12 Volts 89%
13.8 Volts 2 Amps strapped @ 2 Ohm Mono 4130 Watts
14.4 Volt Rating:
14.4 Volt RMS power @ 1 ohm mono 2080 watts x 1CH
14.4 Volt RMS power @ 2 ohm mono 1400 watts x 1CH
14.4 Volt RMS power @ 4 ohm mono 767 watts x 1CH
Efficiency 4 ohm @ 12 Volts 90%
14.4 Volts 2 Amps strapped @ 2 Ohm Mono 4450 Watts
Low pass frequency crossover 30Hz~250Hz
Subsonic filter 10Hz~70Hz
Bass boost @ 45Hz 0~12dB
Phase shift control 0~180 degree
T.H.D @ 4 ohm
I'll be getting the rest of the amps stats and prices soon.
--Chris
Recon 2.4 back from Steve Meade and his Amp Dyno Testing!
--Chris
C2 Audio
C2 Audio
Youngstown, OH
jasonbillnelson
maylar
    Jun 2, 2024
    Jun 1, 2024
