C2 Audio Recon 2.0 Amplifier Group Buy is Live!
C2 Audio
The Group Buy on the Recon 2.0 Mono Amp is now Live and are on Sale! MAP prices for the Recon 2.0 is $599. The Recon 2.0 group buy price is $499. Your purchase of the Recon 2.0 amp on this exclusive Group Buy will also automatically register you to become a new C2 Audio Team member. As a C2 Audio Team member you will gain access to team member exclusive discounts, clothing and other perks. The Recon series Amplifiers are hand assembled in Korea using the highest grade components available making these amps unbeatable in their price range!
Get in on Team C2 Here: C2 Audio Recon 2.0 Group Buy
Just saw C2 Audio post on Facebook that this amp put up 4107 watts at 1 ohm on Steve Meades test bench! I want to see his video of this for sure!
We made some updates to our board with a few upgrades... the Correct name of the amp is now the Recon 2. and Jason the spec sheet you saw was of initial testing. It ended up putting out 4,157 watts @ 1 ohm! Steve made some changes to the test bench and used some fresh 12 awg in all 4 speaker terminals and 0 awg Power/Ground. Check out the updated Dyno Run Results:
12.0 Volt Rating
SMD AD-1 Rating:
1 Ohm Dynamic Burst 3183 Watts
1 Ohm Non-Certified 2782 Watts
1 Ohm Certified 2485 Watts
Oscilloscope Rating:
12.0 Volt RMS power @ 1 ohm mono 2045 watts x 1CH
12.0 Volt RMS power @ 2 ohm mono 1413 watts x 1CH
12.0 Volt RMS power @ 4 ohm mono 789 watts x 1CH
Efficiency 4 ohm @ 12 Volts 88%
12.0 Volts 2 Amps strapped @ 2 Ohm Mono 4400 Watts
13.8 Volt Rating:
13.8 Volt RMS power @ 1 ohm mono 2707 watts x 1CH
13.8 Volt RMS power @ 2 ohm mono 1890 watts x 1CH
13.8 Volt RMS power @ 4 ohm mono 1061 watts x 1CH
Efficiency 4 ohm @ 12 Volts 90%
13.8 Volts 2 Amps strapped @ 2 Ohm Mono 5837 Watts
14.4 Volt Rating:
SMD AD-1 Rating:
1 Ohm Dynamic Burst 4157 Watts
1 Ohm Non-Certified 3537 Watts
1 Ohm Certified 3215 Watts
14.4 Volt RMS power @ 1 ohm mono 2982 watts x 1CH
14.4 Volt RMS power @ 2 ohm mono 2074 watts x 1CH
14.4 Volt RMS power @ 4 ohm mono 1169 watts x 1CH
Efficiency 4 ohm @ 12 Volts 89%
14.4 Volts 2 Amps strapped @ 2 Ohm Mono 6530 Watts
Recon 2.4 back from Steve Meade and his Amp Dyno Testing!
--Chris
Very impressed with the amplifier! I have final artwork from what the heatsink will look like with logo on it. I'll try and have that up later today.
--Chris
C2 Audio
C2 Audio
Youngstown, OH
C2 Audio
