Camry 2007 Dash Kit + Amps
  • 4
CamryMTX
Here is the kit I installed in my Camry, Not bad considering how big the stock radio was.
Here is my 2 amps installed behind rear seat. MTX 4004 4Ch MTX 8001 Mono Amp.
And here is the Subs im powering off of the Mono Amp.
And the rest of the car has Infinity speakers all the way around. 6x9 3 way in rear and 6 1/2 in front
Thanks everyone. Good info. I don't think I want to go above $150-$200, considering its a 2007 hybrid. Now I just have to find something to fit...
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
CamryMTX
CamryMTX
Manassas Va
KINGDELL91
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
