Can a FI BL take 2200RMS Daily?
are you clamping 2200watts with rise, or you have a 2200watt amp. BIG diff....
I ran a sundown 1500 @ 1ohm on the original Q for several years with no issues.
I've been running a mmats dhcx2200.1 on a FI Q d2. Has BP option also. No issues at all...
If you know what you are doing, yes you can run a 2200 watt amp to a bl. You can easily set the amp to work with a bl, and headroom is always nice if you know what you are doing.
If it was me i would get a SSA Xcon- pretty much same money until the 31st
but like some have said - the BL will never see 2200w and the gains could be set correctly
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
If you wire it to 1 ohm it will make 15,000W You should expect to pay at least double the MSRP of that amp in electrical upgrades to properly...
Just playing around. He's not even turning it up...
37
5K
Technically I need to have the internal Regulator replaced, but considering it's cheaper to buy an ECU for 350-400, send it to get the immobilizer...
137
19K
ThomasG
ThomasG
Sick Lake city
dbeez
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
