Can an Alpine MRP-F300 4-Channel 300 Watt be wired 2 ohm to these Alpine SPS-610C
  • 3
Why? You could bridge it for 2 big channels...won't get 2 ohms out of a pair if wired In stereo.What are you trying to do?
Oh my bad, forgot to mention have to connect another pair of 6.1/2 midrange speakers, this amp is 50 watts RMS x 4 at 4 ohms (75 watts RMS x 4 at 2 ohms)
Assuming this amp is definitely 2 ohm stable, which is what attracts me to these amps
Alpine MRP-F300 I can find about $50 cheaper than Alpine MRX-F30
any suggestions
How about running the alpines on the front ch.and the others on the rear?
You can connect the alpines and the midranges for a 2ohm load..rear channels for rear speakers?
How about running the alpines on the front ch.and the others on the rear?You can connect the alpines and the midranges for a 2ohm load..rear channels for rear speakers?
Yea close well here's the incomplete plan but in the works, I have this in storage :Alpine MRP-M500 to this sub Alpine SWS-12D4 ( not installed yet)
I was thinking 1 more pair of mid components to add with the 2 Naxa NX-774 and a 4 channel amp for example what I've mentioned above
Unless you have a different suggestion for good sound quality for mid range speaker set up
Here's a few I'm interested in:
MBQUART FX4.70 4 Channel Amp
MBQUART FX4.100 4-Channel Amp
Currently have a Pioneer DEH-2400 Head unit
2 Naxa NX-774 6.5 Inch 2-Way Coax front doors
2 Pioneer TS-A6964R in rear
so.. what to toss out and what to buy and bring in ?
I picked up 2 sets of MB Quart ONX216 components and an MB Quart REF.50 amp and I'm thoroughly impressed with them. Plus the REF.50 amp is smaller than a piece of paper (except the height of course). I have pictures in my profile if you are curious.
Oh and I found the amp for $87 new and the components cost me $70 a pair.
Try to keep the speakers the same if your going to run multiples...that way they will all sound the same.
Are all the speakers going up front or front/rear?
Even a better deal than I got! I also agree with keeping the speakers the same as pickup1 said.
And I run my MB Quart ONX216 Components at the rated 4 ohms 50 watts per tweet/mid driver and they are crisp, clean, and loud. So I chose not to up them to 100 watts each. But it can be done and I'm sure you will be very pleased with that amp!
I'm enjoying and want more sound upfront room in my doors 1 pair each door
so then all 4 upfront and let the headunit power the 6x9's in the rear
As long as tweeters don't conflict with mid bass of the Naxa NX-774.but I'm fine with another set of them
Besides,If this amp blows them I'm out $22.00 lol
MB Quart REF4.50 2 ohms: 100 watts x 4 Naxa NX-774
Alpine MRP-M500 2 ohms:500 watts x 1 Alpine SWS-12D4
Now curious if big 3 upgrade will be needed along with my factory Alternator 105 Amps
Unless you have subs, big 3 shouldn't be necessary. I put mine in because I was having mad voltage drop running 1 SA-10 at 2ohms and 500RMS before the MBquart setup. I then put in the BIG 3 upgrade and the voltage drop is minimal maybe .5 at most. I added the MBQuart components after that upgrade and saw no change in voltage drop.
Well I have 1 sub its 500rms 2 ohm if wired correctly, plan to install the 2 amps,sub in the trunk, 2 more mids in the doors, bam done
so afterwards I will find a wall at night or get a cheap digital meter to see what the drop will be
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
472
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
691
I am willing to trade both subs for Kicker 46CK4 wiring kit $81 on Amazon https://www.amazon.com/dp/B07NS9DTWW/?tag=caraudiocom-20 T-Spec v12...
18
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
wesburnsco86
wesburnsco86
Kings Mountain,N.C.
jasonbillnelson
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
