Can i connect these?
  • 3
Lol thanks for respondin. Yea i thought about it before I connected it and im like alright I see it the same way as jumper cables work. If a battery is low and u jumper cable it to a higher voltage battery, itll just equalize it and it wont cause a dangerous high current. My worry was that one of my fuses would blow and I would have to end up gettin the back battery charged somewhere to match my front battery.
Another question though, is that always safe to do, if the batteries are the same brand, and the voltages are drastically different? I dont mean like a 12v battery and a 6V battery but like two 12V batteries with big dif voltages
well if a 12v battery is resting at 11v or something, its a bad battery and shouldnt be used. i would say, leave it on the charger over night and see what it sits at over the next day. its always a good idea to charge the batteries before putting them into the car.
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
562
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
758
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
5
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
3K
Carnivorous18
T3h G33k
Carnivorous18
San Diego, CA
Carnivorous18
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
