can i fit a 12" sub in a box only 12" wide??? i need a cut out of 11 1/8"
  • 4
Jeff22
pa
ok i'm kinda limited on space in my extended cab truck. i'm tall and i want my sub behind the driver side seat. the way i want my box designed is so that it sits sideways and fires into the center of the extended cab portion.
basically what i want to know is can i put a 12" that requires an 11 1/8" cutout in a box that is only 12" wide and 12" high. i'm going to make it 14" long which will get me 1.18 cubic feet. i don't know if this will work though because isn't a 12" sub 12inches in diameter?? so i wouldn't be able to screw the sub down right??
what about if i make it 12.5" wide and 12.5" high then make it shorter. would that work better?? i think i could spare the extra .5" in width and height if i can't make it 12x12
Keep in mind that you have to figure in displacement of the woofer and if those are external dimensions (which I assume they are), then you should also figure in displacement of the wood itself. Otherwise, you might end up with a lot less space than you thought, which can produce bad sound, or worse, damage the woofer.
yeah i just thought about that when i put those dimensions in the calculator i forgot to figure in the 3/4" mdf so it will need to be larger than i thought. i think i'm going to shoot for a 1.2cubic foot box before displacement.
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
12
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard...
If you have an OEM radio and amp, chances are that one has bass reduction as the volume rises to protect the paper cones from tearing apart. So if...
6
83
Jeff22
Jeff22
pa
Jearod
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
