Can I run my components off of this amp?
  • 3
I have a pioneer gma 5602 I got for free and was wondering if I could run my 6.5" components off of it. Despite it not having a high pass cross over. I have a 7 band eq kenwood single din. Could I just use that as the cross over while just powering the speakers with the amp? I don't have too much experience with amping door speakers. Any help would be appreciated.
Don't see why not. Just hook it up properly, set gain properly and should be good to go. That's 150x2 into 4 ohms and 225x2 into 2 ohms so watch the power output. What's the comps you have?
Digital designs d series 6.5". So as far as tuning just use the head unit? And thanks for the help
Also I have a sub box with a maximum mounting depth if 6". Would I have a problem using the soundqubed hds2.108 which has a mounting depth of 5.5"? It's going under the seat of a truck btw.
you have to add the box wall thickness to the mounting depth, so its gonna be a very close call if itll work at all if you factor in excursion
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
Chad21000
Chad21000
Savannah GA
youdoofus
