can you run a 4ohm sub at 2 ohms?
Take the + of each sub, wire them together....... and the - of each sub and put them together. Then run the 2 +'s to the + on the amp, and the 2 -'s to the - on the amp. Then your amp will see a 2 ohm load.
Depends on the number of voice coils. if there are only 1 voice coil on each sub then you can run them in parallel to get to 2 ohms. If there are more than one voice coil it gets more complicated. We can tell you how to wire everything if you tell us what amp you have and how many voice coils your sub has.
seriously? didnt bassin just answer that.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
psykotyk
psykotyk
los angeles, CA
sacsking916
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
