Can't Fix Speaker Polarity!!!!!
  • 4
PurpleDiesel
UPDATE:
Problem fixed! after all this time I had no clue it was backwards to begin with lol
How I resolved the issue:
Left the headunit rca as they were
* reversed the headunit > bit one inputs
* left everything else the same
* Reset all features on the bit one and ran the initial setup all over again.
When playing some test tracks I noticed... Polarity of speakers is backwards as right sounds comes from left speakers and vice versa
Headunit -> Bit one -> amps
My Headunit Balance is Reversed because no matter what combination I tried I always got one source that was incorrect so I left it alone.
Head unit balance = backwards
bit one software L+R = correct
bit one controller balance = correct
sound output = backwards
Audio playback:
Right voice comes from LEFT speakers
Left voice comes from RIGHT speakers
Audison bit one software:
Right controls right speakers
Left controls left speakers
At the headunit:
Right fades Left
Left Fades Right
On the Bit one controller:
Right fades right
Left fades left
How in the world do I fix this.... I think it's messing with my imaging also
You have rca's to the bit one and then another set to the amps correct? Your signal is switching sides somewhere. What kind of wire connects the controller?
FYI this is not polarity, this is balance.
Correct TY
I remember now.
My Headunit Balance is Reversed because no matter what combination I tried I always got one source that was incorrect.
That's messed up. What's the head unit?
After doing all this the software corrected everything...
Thanks for the input guys
So is the radio harness spliced direct to the OEM harness? There is no adapter harness?
12
Nothing wrong with the system. humming sound. Just the amplifier. Just switch it to volume maximum, then enjoy the music there. Loud. Sorry...
12
Sounds like an issue with the programming in your head unit. The designers didn't anticipate the day where the head unit would need to read 700...
So a hard-reset seemed to reduce the frequency of the issue, but it didn't go away. In fact, I can re-create it repeatably by going through...
PurpleDiesel
PurpleDiesel
Northern Cali
PurpleDiesel
Decebal
    Jun 10, 2024
