Cap Placement??
headshothills
I have 2x 1F Monster Digital Caps and was wondering what would be the best configuration for them when wiring.
I plan on running a Memphis MCA300.4 to 4 Memphis 15-MSYNC6.5's in the doors, and running 2x Memphis M310D4 powered by a Memphis MCD1000. I have 1/0 running to a big Power Dist. Block in the cab, and 4AWG to each amp. Should I run 1 Cap in-line to each amp, or should I tap off the Power Dist Block and connect both Caps in with that, or something different?
Wow, that was a thoughtful statement there.
Place caps in my house on a Shelf, wire them to a 12v battery, and use a paper weights... //content.invisioncic.com/y282845/emoticons/suicide.gif.a649d21efc0d1fd4890a6428166586c1.gif//content.invisioncic.com/y282845/emoticons/youreawesome.gif.a27e190c662afa8e2be5686b27bd1659.gif
if you cap has a voltmeter on it, use it. if not, it will be of no use to you. i use my simply to know what voltage my system is at. and it gives off a cool blue light....
Wow...Really, caps are basically junk? And to think they sold when I bought them for 199.99. They are the Monster Digital Caps, they have the Volt Meter in LCD right on them.
So, trashomundo to the caps, do the big 3, and call it a day, or run another batt in the cab, and then to the Power Distribution block...
I thought these caps were the ticket, must be old school in me...
on your head //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Thank You for that link!!
Would you guys even recommend adding a battery, meaning a 2nd one in the cab with this setup after doing the Big 3??
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
862
You fell for the capacitor meme. Throw that **** away.
897
508
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
Yes, time to move some stuff for sure. Have a little mini CA warehouse in the garage!
10
897
headshothills
headshothills
Phoenix, AZ
headshothills
