car audio newbie
  • 3
xmandu2000
Hi, I've got an 03 Acura 3.2 TL w/o Navi. Stock Bose 6 disc changer has been removed because of a stuck CD and Acura wanting $400+ to replace.
In its place is a Pioneer 50 WPC head unit mp3/wma with attached iPod cable for my iPhone.
During the install process the tech has to disconnect the subwoofer becasuse it wasn't compatible for some reason. No big deal.
Problem - the 4 indoor speakers (according to BB 5.25s in the front and 6.5s in the back) are starting to sound like crap at higher volumes. I like to turn it up a lot. I believe these are Bose speakers which can't seem to handle the wattage? surprising to me that they can't. Anyway, now I am considering replacing them. I am on a budget but guess I can do this in two sessions (getting front replaced 1st then rears later down the road).
Any suggestions in speakers that will be better than the factory installed Bose but don't break the bank. I'm look at $75 a pair for the front and rear plus installation costs? So probably around $300-350 total if I can keep it in that price range.
I live in south Denver if that helps an audiophiles in the CO.
thx for any advice
TC
Thanks for getting back to me. No amp at this time. future upgrade due to budget concerns at the moment. Anyway, I ended up getting 2 pair of Polk Audio DB 651s 6.5s for the doors and just need to find someone to install it. I hope to put in an amp this summer.
You shouldnt ask what speakers to get and then go out and buy some. I had those and they were pretty good but you could have got something better. Those speakers will sound way better amped.
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
678
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
420
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
951
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
623
xmandu2000
xmandu2000
denver, co
97chameleonbird
Doxquzme
    May 19, 2024
Dylan27
    May 19, 2024
