car burning oil?
well, it's not a good thing.
if it only blows grey smoke out the tailpipe(s) on startup it is caused by the valve guides being worn or broken. valve guides are cheap but require removal of the head to replace. it would be wise to have your heads polished and the guides installed by a reputable machine shop.
if it consantly blows grey smoke while driving it's prolly the rings. this would require a complete engine overhaul.
not fixing the problem leads to embarassment from having a smoking car, fouled spark plugs, and loss of compression. it will only get worse as time goes on.
if it is black smoke...it's fuel, not oil. a regular old tune up will help(including adjusting your air/fuel ratios).
also i had an old ford with aftermarket valve covers. the guy had rebuilt the motor twice(with edelbrock intake and carb) in two months because when he started it... it would go through like a quart of oil in a day. well i picked it up and it turns out that the valve covers didnt have a plate under the pcv valve so it was ******* oil right through the intake. i fixed that and the truck has been running strong for almost 5 years now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif still goes through a quart every months or so but i figure that much oil going through the intake had to hurt something......
anyways if its a quart of oil in a month its not that bad but if it gets down to every 1 week start saving up for when it goes out.....
Thanks. It blows a little grey smoke out the tailpipe on startup. I'll probably leave it alone because it only takes like a quart a month. Plus Im selling the car as soon as I get it painted.
also i had an old ford with aftermarket valve covers. the guy had rebuilt the motor twice(with edelbrock intake and carb) in two months because when he started it... it would go through like a quart of oil in a day. well i picked it up and it turns out that the valve covers didnt have a plate under the pcv valve so it was ******* oil right through the intake. i fixed that and the truck has been running strong for almost 5 years now :)QUOTE]
Can you say 2 stroke? Hahaha!
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
119
A Link would be very helpful. Id be interested in taking a look at some gear
164
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
618
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
newb
newb
los angles, ca
LoudCrownVic
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
