Car lost all power when I wired my second amplifier
  • 3
loz88
15
UK
Hey guys,
I have one amp running to my front components. Today I wired my second amp for my sub up (it had a seperate ground, spliced into the original remote wire and seperate power leads). Each power lead goes to the positive terminal on the battery as you would expect.
I was listening and everything was working then I went to start the car and suddenly everything went dead, the car wouldn't start, lost all power to everything, I went and unhooked the amp and everything came back. I tried again and this time everything worked and the car started but every now and again the amps would both shut off and then come back on randomly, I noticed if I move the power leads then they do a small spark on the battery terminal.
Anyone have any ideas what is going on? I am guessing the battery is not liking having both power leads together on the terminal? Or I am thinking maybe it is something as simple as not having it tightened enough
Hey guys, I noticed if I move the power leads then they do a small spark on the battery terminal.
Seems as though you've answered your own question. The spark is a direct result of the problem. I know that having two positive leads coming off the battery does not cause any ill effects...if they are wired properly.
Put the phone down and DRIVE!!
Thats kind of what I am asking, why would it cause a spark, I have just added the next power cable on top of the old one (which I never had problems with) and then tightened the bolt back up, should I try a new power lead?
---------- Post added at 03:53 AM ---------- Previous post was at 03:53 AM ----------
Lose connection. Do you by chance have a distribution block?
Nope just wired both straight to the battery, ill make sure it is tighter then and give it a try thanks
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
192
A Link would be very helpful. Id be interested in taking a look at some gear
200
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
647
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
loz88
loz88
UK
Boomin_tahoe
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
