car peek ?
  • 5
28hz peak? sheesh! what do you drive a bus? ...just kidding. How does your box load....where are the woofers moving the least, 28hz? if so, shorten the port like said...get it in the mid 30's. but if not....deaden whatever panels still flex a good amount, it should help.
but if its tuned the same as your box for 12's means a miscalc/different woofer firing/port firing combination is giving you that.
the box i have now takes up the whole hatch and it is subs up port back
but when i hit the low notes every panel flexs and the back of the hatch where the taillights are flexs a inch or so i have had to repair sheetmeatle there as well and i have some 1" birtch do you think it will help and to bolt it to that kidda like a reflex pad
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
207
A Link would be very helpful. Id be interested in taking a look at some gear
215
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
654
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
mecaspl151
mecaspl151
sugervally
mecaspl151
