Car power issue - amp works indoors, doesn't work in the car
  • 1
Willydk
14
Denmark
So hopefully my last thread about this //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Long story short:
Tested my amp indoors, tested speaker indoors - works perfectly fine.
When I power it up in my car, using exactly the same setup as indoors(phone rca) it powers up but does not output speaker voltage.
I'm 100% sure that it's power/ground issue. But what is wrong?
I'm using ~1meter of "Car Hi-Fi cable, 10mm2, 60A" for power, and same type of cable for ground.
The car is bmw E46, I tried wiring ground to the same spot where battery's ground cable is connected, and also on a bolt in upper trunk area.
What could be wrong?
Oem cables are readily available for most vehicles. Check rockauto. Anything less will be a future headache.
10
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
563
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
966
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
799
Willydk
Willydk
Denmark
Willydk
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
