center console box build: kerf, fiberglass, plexi, vinyl, paint
Flastrongman
Ft Myers FL
I guess when you build enough boxes it's hard to do something different every time. I wanted to this build to incorporate a wide array of techniques. It's my first time trying this many things to one box, so it can only get better from here.
the beginning:
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
348
Well I ordered an oscope. Should be here today. And this beautiful beast showed up today. I’m gonna have to redo my battery and ground terminals...
36
6K
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
246
Audio Control ESP 3 is the way to go ..if your wanting to do a quality center channel setup ...
985
Flastrongman
Flastrongman
Ft Myers FL
THATpurpleKUSH
    May 12, 2024
Brendon Jenness
    May 11, 2024
