Center dash speaker wiring and amp spec
  • 2
BMDUBS
Canada
Hi all, sorry for the long newbie post!
I have a 09' BMW X5 with a factory system with a center dash speaker that is 3.5". The front doors have 3.5" also with tweeters higher up on the door, rear doors with 3.5" and 2 small subs under the front seats.
My question is about specifying an amp and how to wire the center channel. I wanted to get a 5 channel but most of these are set to run a sub with the 5th channel so have been thinking 1 - 4 channel for the front door speakers and wiring the center channel in with the front door speakers and the rear doors on the rear channel with a dedicated amp for the under seat subs. So total of 6 channels. Is this the way to go to retain fader/L/R control etc?
I saw a wiring diagram online to add the positive of the center speaker to the front left speaker positive terminal and the negative of the center speaker to the right front speaker negative terminal. Is this the direction to go to wire this? With 4ohm speakers what would this do to the final resistance the amp would see in this configuration?
Any ideas and direction would be most appreciated TIA
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
646
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
476
Audio Control ESP 3 is the way to go ..if your wanting to do a quality center channel setup ...
Well I ordered an oscope. Should be here today. And this beautiful beast showed up today. I’m gonna have to redo my battery and ground terminals...
36
6K
BMDUBS
BMDUBS
Canada
Louisiana_CRX
