Changing pulleys
  • 3
Crownvicon28s
God 1st
My stock pulley is 2 3/8''. If I was going to go with a smaller pulley what size should I go with? Would I need a smaller belt if I installed a smaller pulley? I was thinking either 2'' or 1 7/8''. Will going with too small a pulley cause problems? I drive mostly around town occasionally on the highway.
Here is a link to the pulleys I was checking out.
http://www.alternatorparts.com/pulley_size.htm
Get the smallest one you can, but that still won't fix your issue. Your alt is not putting out enough or you got a shitty battery. Try addressing both of those.
I changed up some of my wiring. Holding 12.6 with lights and heat on full tilt. Im satisified with my alt just dont get much amperage at low rpm's. Im thinking a smaller pulley would fix this and hopefully the voltage would hold a little higher. Would I need a smaller belt?
Probably just go with the smallest see how it works. If im not satisfied then I will get another alt.
This could be due to a voltage drop. There's no constant voltage going into the head units. It's always changing. At which point this could be...
8
Simply put its an oldschool simple way of keeping the midbass in phase with each other when they are firing at each other in the front...
789
I am about to buy the Pioneer DMH-WT76NEX head unit. It has one USB Type C output. My Honda has an HDMI port, 2 USB-A ports, and one charger...
Haters are going to hate. It usually goes back to something personal. He would probably take it in his dirty penny to have a full Sundown sub and...
24
5K
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
Crownvicon28s
Decebal
    Jun 10, 2024
