Channel Distribution Question
  • 2
erutter11
Hi,
Alpine iDA-X303 4 channel head-unit (16 watt RMS, 45 peak)
Rockford Fosgate R1653 6.5 (80 RMS, 160 peak)
Kenwood KFC-6982ie 6x9 (80 RMS, 450 peak)
I'm buying Sound Storm SSL F2.600 Amp for my 6x9s and a Clarion EQS746
7-Band Equalizer.
I'm wondering if when I run the SSL amp to the 6x9s, can I run 2 channels from my deck to each 6.5 or is that impossible?
Thanks.
two channels for 69's two for 65's
simple.
assuming the HU will be okay with using rca and line out at the same time...which it likely will.
331
461
10
841
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
478
erutter11
erutter11
grayling
shaneb
