Charging lithium
  • 2
How often are you charging? I charged mine once when I built it over a year ago and maybe a couple times while I had the car pulled apart. I just use a power supply.
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
14.6 is max charge for headway. 3.65 volts per cell. There should not be any voltage drop from your alternator wiring to battery so 14.8 is too high.
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
For the pt cruiser, neons, and other pcm controlled charging systems these parameters need to be altered with tuning software. The two tuners I...
6
Why not wire to one ohm? You could achieve the same output with a smaller amp wired to one ohm. If you want the big amp for future planning, you...
13
KicktheSDbasshead
2 builds 2 feet
KicktheSDbasshead
San Diego
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
