cheap amps any good?
  • Thread starter <dustinleavitt>
  • Start date
  • Replies 6
  • Views 3K
<dustinleavitt>
Guest
I have been thinking of putting some subwoofers into my old ford piuckup single cab and i was wondering if a legacy or pyramid amp would have enough power to run a pair of tens are these things any good i dont have much money to spend and suggestions????
For the most part you get what you pay for.
Try to find a good sale on a higher quality amp.
Lanzar Vibe, US Acoustics, Profile Clarus are decent cheap amps.
In the case of not having much money for equipment, be very particular in how it is installed. Lower quality components CAN sound good if set up correctly.
Hello,
You'd be better off with Jensen amplifiers or Profile rather than settling for those legacy amplifiers. You can get a good amp for cheap. You may want to even go with the ebay or ubid route to try and get a cheap price. Bottom line is try to stay away from brands like legacy or pyramid. You won't be happy with the sound quality and the output it presents, and will be dissappointed with them.
Yea. Jensen are very good cheap amps. I had a pair of Jensens for some time running 2 8's for a time and 2 12's for the latter part of their service to me. I also higly recommend Kenwood's entry level amps. Very powerful and pretty damn cheap too. Steer clear of Legacy and Pyramid. Lots of problems. (Out of JcWhitney?) Another point to take into consideration is what TYPE of sub you're driving. If you're driving some low-end Pyramid or Pyle sub, the good amps will melt the voice coils in those subs like the Snickers bar your uncle sat on. Match quality to quality and crap to crap. It's the only way to play.
Check out Power acustic i run one on my 2 10's and iT sonds great
Just becuz a braND ISNT WELL KNOW IT DOSENT MEAN ITS NO GOOD
My first install on my vehicle was in '94 right before I turned 18 😂 I'd "helped" on a few starting at 16 but my helping was mainly gofer work...
19
3K
I have not really heard anything bad about Vibe Audio. If you are buying it new, then no reason to not try it out. It may have a 3 month...
Starting from scratch don't have an amp yet gonna wait till I make a decision on which subs right now I'm just trying to settle on which subs I'm...
5
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
440
Guest
n2audio
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
