Clarion CX6210 Mini 2 Channel Marine
  • 1
trumpet
Barry Schanz
Clarion XC6210 Mini 2 Channel Marine
1 in stock
New
FEATURES
  • 350 Watts of Maximum Music Power
  • 125 Watts × 2 Continuous @ 2-Ohms
  • 85 Watts × 2 Continuous @ 4-Ohms
  • Conformally Coated PC Board
  • Stainless Hardware
  • MOS-FET Power Supply
  • 12dB/Oct. High/Low Pass Electronic Crossover, 50Hz-500Hz (×10, 500Hz – 5kHz)
  • Soft Turn-On and Turn-Off Circuitry
  • Ground Loop Isolation Circuit
  • Corrosion Resistant Nickle Plated RCA, Power, and Speaker Connections
Circuit Design Achieves High Quality Sound
Clarion amplifiers feature uncompromising resistance to magnetic noise, thereby minimizing distortion, as well as high quality block terminals to offer low electrical and contact resistance. Easy subwoofer system configuration is possible with the embedded high pass and low pass filters. The result is high quality sound you can enjoy in a variety of systems.
Corrosion Resistant RCA and Block Terminals on all XC series Amplifiers
By utilizing corrosion resistant RCA and block terminals, XC series amplifiers offer improved durability and reliability in harsh environments. The XC series amplifiers are true marine amplifiers with oversized aluminum heatsinks and locking power terminals for the harsh marine conditions.
MOS-FET Power Amp
There’s only one way for Clarion’ s main units to deliver unyielding power output and linearity: MOS-FET amplification, or Metal Oxide Semiconductor Field Effect Transistor amplification. Smaller and more efficient than conventional power supplies, a MOS-FET amplification circuit delivers power with less distortion and zero On/Off switching noise. This means you can crank up the volume or set it to easy listening. Either way, your sound will be crystal clear.
2-Ohm Stability
Utilizing this design for peak performance and unwavering reliability, Clarion’s amplifiers can drive lower impedance loads for increased power.
$299 shipped
MAP
Free shipping to the Continental US
Looks similar to this: https://www.sonicelectronix.com/item-17681-Clarion-CX609.html I'd call Sonic Electronics and see if they have what you...
Thats its manual fore using, not Tecnical.expaining , have pinted out service manual., and the cable i think was fore swc,its made fore satelite...
I dont think anyone can answer that question of if a BTooth adapter will sound as good as a CD? Only one would know by actually using the same...
4
I would recommend to get on F.Book @ Old School Stereo and run a Want To Buy thread there. Im sure someone is hoarding one, maybe even a BNIB one...
I know what you mean ....its a pain going in all those menus ...i think kinda look at these new decks like old school trunk mount processors...
11
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
