clarion eqs 746 help!
  • 4
Corybrdmn
Ok so i have a clairon eqs 746 i installed it sucessfully the first time what i did was i ran the 12 volt wire and tapped it into my remote wire of the eq and ran my remote wire and tapped that into the amp wire of the headunit and ran the ground and tapped that into the ground of my headunit. I know the 12 volt power wire tapping it into the remote wire is retarted but i originally tapped it into the headunit power wire and it wouldnt turn on. So it was working but everytime my bass hit the lights on it would dim and the last 4 knob lights dimmed all the time when the sub wasnt even on. So what i did to make better power supply i ran à power wire straight from my 2nd battery and ground straight from it also and connected those into the eq and kept the remote wire the same and nownit doesnt even turn on so idk what to do?
I have the same EQ and I ran the power and ground from my battery and used the remote wire coming out of my HU and it worked fine. So like mylows said it is probably messed up
Looks similar to this: https://www.sonicelectronix.com/item-17681-Clarion-CX609.html I'd call Sonic Electronics and see if they have what you...
Thats its manual fore using, not Tecnical.expaining , have pinted out service manual., and the cable i think was fore swc,its made fore satelite...
I dont think anyone can answer that question of if a BTooth adapter will sound as good as a CD? Only one would know by actually using the same...
4
I would recommend to get on F.Book @ Old School Stereo and run a Want To Buy thread there. Im sure someone is hoarding one, maybe even a BNIB one...
I know what you mean ....its a pain going in all those menus ...i think kinda look at these new decks like old school trunk mount processors...
11
Corybrdmn
Corybrdmn
Dunkirk, Ny
Side Show
