Clarion Full Digital - Crossover Help
Jackers
Hi,
I am trying to setup the new Full Digital System from Clarion (Z3 tweeters, Z7 mids for front and rear doors, and dual Z25W subs.
This system is unique in that it processes the digital signal and sends it to the speakers in 1s and 0s. From there, the speaker processes that into cone movement. This eliminates the need for big amplifiers while eliminating electrical interference.
So, I'm trying to set my active crossovers for this, but because it is still so new, there isn't a lot of help online. Here is what I'm working with and what my original settings are. Any help would be greatly appreciated!
Z3 tweeters:
6ohm
1.5kHz ~ 40kHz
Z7 mids:
Driving section:
89dB at 1W S/N
102dB Dynamic Range
10Hz ~ 48kHz +/- 2dB Freq Response
Speaker section:
4ohm
28Hz ~ 15kHz
60Hz Fs
0.85 Qts
Z25W subs:
Driving section:
90dB at 1W S/N
103 dB Dynamic Range
Speaker section:
4ohm
20Hz ~ 200Hz Frequency Response
38Hz Fs
4.75 Qms
And this is what I have so far. Any advice on how to dial this in?
Tweeters:
HPF = 3.15kHz
Slope = -24
Gain =-9.0
Phase = Normal
Mids:
HPF = 80Hz
Slope = -24
LPF = 2.5kHz
Slope = -18
Gain = 0
Phase = REV
Subs:
HPF = 20Hz
Slope = -12
LPF = 80Hz
Slope = -12
Gain = 0
Phase = Normal
Those speaker specs are outright ********. Why are the mids out of phase?
Where are the tweeters placed?
How much power?
What makes you say the specs are ********? I'm just asking as I don't have a good background in this. I think they sound cleaner than any speaker I've ever heard, but honestly, that isn't saying much. I'm deferring to you guys here!
I thought they sounded better out of phase.
Tweeters are in the front corners of the dash, right where the dash meets the windshield.
As for power, the is only a 12v signal going to the Z3 digital processor and 12v to each sub. It's one of the benefits of the full digital signal.
Clarion U.S.A | Full Digital Sound system
https://www.crutchfield.com/S-qnCW0cPi0J6/p_700FDSX/Clarion-Full-Digital-Sound-System.html
PASMAG | PERFORMANCE AUTO AND SOUND - Clarion Full Digital System Review
Clarion has partnered with Trigence Semiconductor and their Dnote technology
This system is basically a consumer-friendly taste of technology that will be in OEM car entertainment systems as that's where Clarion earns most of their income.
https://www.trigence.com/dnote
Thanks for all the value you bring to the thread. //content.invisioncic.com/y282845/emoticons/plthumbsdown.gif.d7966af824c93c6021d1aae1778b1c19.gif If you don't know how to tune it, just move on.
[quote name='Jackers']Thanks for all the value you bring to the thread. :thumbdwn: If you don't know how to tune it, just move on.[/QUOTE]
papermaker can be kinda angry at times, gets pretty argumentative too. There are several people on this forum who are very helpful, just may not be familiar with your equipment. @Jeffdachef @LosIsATool are two q minded folks who might be able to shed some light
How much power?
Mids are sometimes put out of phase as a sort of time-alignment adjustment and/or to help with phase-shift from the filters.
Thanks! Should I do -24 slope on the subs as well?
The steepest slope possible is not always ideal. Especially for mids and tweeters. You can run everything at 24db slopes if you want, but you may find you are introducing holes in your over all frequency response. And the shallower the slope used, the less phase delay you will introduce into the signal. Ideally we would need no filters at all, but a more realistic ideal would be all 1st order crossovers (6db). Usually the subs are set with a very steep slope, mids HPF is set fairly high, and then once you get into interaction between the mid and tweeter, critical listening and fine tuning will give you the best results. Remember, the environment of your individual car will play a role in proper final tuning, so manufacturer specs or even specific freq advice given from well meaning people on the internet will only get you so far.
[quote name='youdoofus']papermaker can be kinda angry at times, gets pretty argumentative too. There are several people on this forum who are very helpful, just may not be familiar with your equipment. @Jeffdachef @LosIsATool are two q minded folks who might be able to shed some light[/QUOTE]
I get it, because t it gets tiring on message forums. Like would anyone talk like that in person?
The steepest slope possible is not always ideal. Especially for mids and tweeters. You can running everything at 24db slopes if you want, but you may find you are introducing holes in your over all frequency response. And the shallower the slope used, the less phase delay you will introduce into the signal. Ideally we would need no filters at all, but a more realistic ideal would be all 1st order crossovers (6db). Usually the subs are set with a very steep slope, mids HPF is set fairly high, and then once you get into interaction between the mid and tweeter, critical listening and fine tuning will give you the best results. Remember, the environment of your individual car will play a role in proper final tuning, so manufacturer specs or even specific freq advice given from well meaning people on the internet will only get you so far.
This is what I started with before I installed the subs:
HPF = 3.15kHz
Slope = 24
Gain = 0
Phase = Normal
Mids
HPF = 80Hz (my EQ only allows 80 or 100)
Slope = 24
LPF = 2kHz (my EQ only allows 1.6, 2, 2.5)
Slope = 12
Gain = 0
Phase = Reverse
I even messed around with lowering the HPF and raising the slope, but I really liked my latest settings above.
This is what I started with before I installed the subs:HPF = 3.15kHz
Slope = 24
Gain = 0
Phase = Normal
Mids
Slope = 24
Slope = 12
Gain = 0
Phase = Reverse
Stick with what sounds best to you and you can't go wrong.
Looks similar to this: https://www.sonicelectronix.com/item-17681-Clarion-CX609.html I'd call Sonic Electronics and see if they have what you...
Thats its manual fore using, not Tecnical.expaining , have pinted out service manual., and the cable i think was fore swc,its made fore satelite...
I dont think anyone can answer that question of if a BTooth adapter will sound as good as a CD? Only one would know by actually using the same...
4
I would recommend to get on F.Book @ Old School Stereo and run a Want To Buy thread there. Im sure someone is hoarding one, maybe even a BNIB one...
I know what you mean ....its a pain going in all those menus ...i think kinda look at these new decks like old school trunk mount processors...
11
Jackers
Jackers
Maryland
youdoofus
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
