trumpet 5,000+ posts
Barry Schanz
Clarion XC1410
1 NIB available
This is a micro 4 channel amplifier. Are you worried about where to fit an amplifier? Small is IN, and with the small size also comes low current draw. Depending on your existing wiring you might be able to avoid running a power cable through the firewall.
・ 75 Watts x 4 Channel @ 2-Ohms
・ 50 Watts x 4 Channel @ 4-Ohms
・ Selectable Sensitivity LOW/HIGH
・ Class D Power Supply and Output Stages
・ Power MOS-FET Switching Transistors
・ Soft Turn-On and Turn-Off Circuitry
・ Ground Loop Isolation Circuit
Selectable High Pass Crossover (60 Hz, 90 Hz, FLAT)
4-Channel RCA Input
4-Channel High Level Input
4-Channel High Level Speaker Output
Dimensions (W × H × D) Inches : 7-1/8 (W) × 1-3/8 (H) × 2-3/4 (D)
$85
Free shipping to the lower 48 states.
Clarion XC1410
1 NIB available
4-Channel RCA Input
$85
