Clif Designs CD960HC MonoBlock High-Current Car Amplifier
  • 3
Jason19
1. Product: Clif Designs CD960HC MonoBlock High-Current Car Amplifier
2. Specs: 240W RMS Pwr x 1 CH @ 4 Ohms
700W RMS Pwr x 1 CH @ 2 Ohms
1000W RMS Pwr x 1 CH @ 1 Ohm
1200W Max Pwr x 1 CH @ 1 Ohm
Unregulated PWM Power Supply
1 Ohm Stable
Internal Cooling Fans
THD @ 4 Ohms
@ 2 Ohms
@ 1 Ohm
S/N Ratio >99dB
Channel Separation >60dB
Frequency Response ±0.5dB 10Hz-20kHz
Crossover Frequency LPF 35Hz-250Hz
Crossover Frequency HPF N/A
0 -- 17 dB Bass Boost 40Hz
Low Level Input Range 200mV - 8V
Input Impedance 47k Ohms
Damping Factor 310
Fuse 30 Amp x 3
Dimensions (H x W x L) 12.1" x 2.5" x 14.7"
3. Description/Condition: Clif Designs CD960HC MonoBlock High-Current Car Amplifier. The amp is kinda scratched up but it works perfect. This amp does rated power and will do more power with more voltage. Im asking 75 firm alot of power for a small price.
4. Price: : 75 plus shipping
5. Pictures:
video of the amp working
There its designprogram to use fore bass boxses , if you now all parametre of the subwoofer , the made the best solutuon fore you
49
4K
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
7
4K
Jason19
Jason19
Kenosha Wisconson
vanburi
Decebal
    Jun 10, 2024
