Cmax vs spim08hp?
  • 2
Vogey84
CarAudio.com Recruit
36
mn
They both are fairly cheap, was looking at getting a pair of 38 cell cmax mod. Or roughly the same ah worth of spim08hp cells is either one stand out as being better then the other? I'm leaning towards the cmax mainly cause I think they might tolerate severe cold better then the others
Cmax are more powerful but require compression the spim08hp cells only require containment and often come with the cell holders so all you need is properly cut all thread and bus bars.
Personally I don't want to deal with cells that required compression. They tend to be a big issue if the compression isn't quite right.
My budget was involuntarily reduced recently, that along with the cmax modules I was looking at were not the correct ones for car audio apparently. Making a 96ah bank of spim08hps stand out as the only affordable choice at this time. I'm ditching the LA Batt under the hood and 2 on frame rails behind rear tires keeping the ixous ultra cap (Goin on frame rail) might get the caps off battery hookup 18 2.7v 3000farad caps for <$300 for other frame rail though I'm on the fence about spending that on caps or just getting another 96ah bank
Hmmm, taking a stab here. This assumes you can use (and own) a volt meter and can test the individual cell(s). Here is a link that might help...
So probably not optimum, but still if they rest at the same voltage they won't be fighting each other when you're not going hard on them.
Vogey84
Vogey84
mn
Vogey84
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
