Complete amateur needs help fixing cable
  • 1
pipjon
Without discussing all the options I have considered the facts are that:-
In a new VW golf plus
1)I want to use my bluetooth headset with my PDA (on top of dash) for calls
2) I want to play audio from the PDA through my car aux which is - unfortunately - in the centre console between the front seats.
I can do this via a bluetooth transmitter and a receiver, but I can't find ones which can transmit/receive whilst charging.
FM transmitters in London, UK suffer from a lot of interference from pirate radios etc.
So I need to either take a 3.5mm aux cable from top of dash and swap out the xisting aux cable (THis via drilled hole in top of dash or possibly run behind front plate of unit (both tiresome and messy options) OR run a 2m aux cable from top of dash to aux jack in centre console.
This would also be messy but a lot easier BUT how do I fix the cable to the plastic trim on the dash, around contours etc. to get there. Are there special fixings, adhesive hooks etc. which you can get in a dark or charcoal greyish colour?
Regards Jon Halperin
  • Locked
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
3K
I hope it ended up helping someone in here. I was right there on the Morels, but didn't need em, so I dropped out earlier than I would have, I...
14
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
Problem resolved - Found a scrap Astra that was fitted with that same unit. Salvaged the Display and original plugs and wired it up on the dining...
pipjon
pipjon
London, UK
pipjon
Decebal
    Jun 10, 2024
